Valve adjustments
Old Oct 19, 2016 | 08:50 AM
T-IROC87's Avatar
Valve adjustments
What are the indicators that valve adjustments are in order? 1987 IROC-Z 305 5.0 TPI
Old Oct 19, 2016 | 09:04 AM
Re: Valve adjustments
No ticking when it's running (tells you they're not too loose), valves all close completely when they're supposed to (tells you they're not too tight)
Old Oct 19, 2016 | 10:09 AM
T-IROC87's Avatar
Thx for ur reply
So if there's ticking an adjustment is in order??
Old Oct 19, 2016 | 10:36 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Originally Posted by T-IROC87
Thx for ur reply
Yup there are a few methods I usually do the EOIC method works well.
Old Oct 19, 2016 | 10:59 AM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Thx for ur reply
Well, that depends. Is it ticking because you're adjusting them and haven't finished adjusting? Or, did it just start ticking? In which case, you need to find out what's broken, bent or worn-out and repair/replace it.
Old Oct 19, 2016 | 12:11 PM
T-IROC87's Avatar
I dnt have any ticking, basically just want to know what the symptoms are since a friend mentioned it but wasnt able to tell me how to determine if an adjustment was in order.
Old Oct 19, 2016 | 12:34 PM
OrangeBird's Avatar
Car: 1989 Firebird
...... a friend mentioned it but wasnt able to tell me .......
sounds like the problem right there , ya need to be talkin to friends who know about the stuff they mention , instead of that guy .....
