Squeeky balancer
Old Dec 28, 2001 | 09:17 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
Squeeky balancer
I have a 305 in my fbody and the balancer rubs against the timing cover. Is there some kind of spacer or something that I could get to go between them or what? I have pulled the balancer twice and put it back on with space inbetween the two but it seems to move back on me. Thanx.
Old Dec 28, 2001 | 10:18 PM
R.O.B.'s Avatar
Sounds like the balancer went bad. Same thing happened to me. Just replace it.
Old Dec 28, 2001 | 10:25 PM
Guest
Guest
Posts: n/a
Yep, if its rubbing on the timing cover, its time to replace it. Soon would be good, before it rubs a hole in the cover.
Old Jan 1, 2002 | 08:06 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
The rubber that sits between the inside and outside of the harmonic balancer is probably worn away and so the outer part is sliding back ( hence the rubbing). i would replace this as soon as possible but until then spray WD-40 to keep heat down. The lubrication will slow the process of rubbing the metal away and will temporarily take care of the noise.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
