How to test oil pressure
Car: 90 Formula / T-tops
Transmission: MD8
Hello Everyone!
Is there an easy way to put an oil pressure test gauge on a 1990 305 ?
Hoping not to have to crawl under car and disconnect the sending unit.
Thanks in advance!
Thanks in advance!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How to test oil pressure
Iirc in 90 the rear china wall Port and above the water pump were omitted from the block. The only Port is above the oil filter.
Transmission: MD8
Does the oil sensor need to be pulled in order to test, or is there a separate plug to put a gauge in?
