1/4 mile times
Old Jan 18, 2017 | 06:42 PM
Chevy Iroc Z's Avatar
Car: 86 irocz
Engine: 350 afr heads comp cam
Transmission: 700r4 3000 stall
Axle/Gears: 4.10
1/4 mile times
Hey wondering if anybody has this same set up and can tell me if this is as fast as it will go in 1/4 mile with the components that i have.
the motor is zz4 shortblock with afr 1034 heads milled to 60cc.
cam is comp cam part number 08-432-8
carb is 750 ultra dp.
gears are 4.10
700r4
tires are the mickey street et
1 5/8 shorty heeders not sure if they are too small
car ran 12.80 at 108mph
i also had 116 octane in it not sure if it helped or not. motor seems to run good. just not sure ifthere is any more left in it or is this all i get.
Last edited by Chevy Iroc Z; Jan 18, 2017 at 06:45 PM. Reason: left something out.
Old Jan 19, 2017 | 06:32 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: 1/4 mile times
12.8 for a street car is a good time - not many 30 year old 12 second street cars out there!
Realize that's probably 2.5 to 3.0 seconds faster than it was stock.
Old Jan 19, 2017 | 07:06 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: 1/4 mile times
That's pretty good
That's a lot of cam. What is your 60' time?
What torque converter are you running? There could be opportunity for improvement there.
1-5/8" primaries aren't holding you back at this power level. However, with that much cam duration, longtubes combined with a good free-flowing exhaust could help. What's the rest of your exhaust consist of?
Old Jan 19, 2017 | 07:25 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 1/4 mile times
Yeah not to bad a time there. 116 oct certainly isnt needed so save the money
93 oct might pick up some actually
Keep playing with the tune there should be some more in that setup
Old Jan 19, 2017 | 08:54 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 1/4 mile times
What does the exhaust look like after the headers? Are you running a custom Y pipe? I know a lot of the pre fab Y pipes have **** mergers and really restrict flow.
Your 3000 stall is probably just fine
What tuning have you done with the carb maybe invest in an A/F gauge and get it dialed in
Old Jan 19, 2017 | 09:04 AM
86LG4Bird's Avatar
Re: 1/4 mile times
I saw the TC stall in his profile.
My question regarded what type TC, ie. 12" or 9.5/10"
Old Jan 19, 2017 | 09:35 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: 1/4 mile times
Zz4 is relatively low compression. 230 deg cam is gonna make it soft under 4000 rpm. For best 60 ft's i would run closer to a 3600-4000 rpm stall speed in a good quality 9.5" converter
I've done a very similar combo before. Was a 12.2 at 112 mph deal with valve float in good air down south. Probably would have gone high 11's at 115 with correct valve springs
Old Jan 19, 2017 | 09:43 AM
86LG4Bird's Avatar
Re: 1/4 mile times
Zz4 is relatively low compression. ....
and his 60cc chambers are even bigger than the stock ZZ4 heads
Old Jan 19, 2017 | 11:21 AM
Car: 86 irocz
Axle/Gears: 4.10
Re: 1/4 mile times
Yes not bad time just thought with the afr heads it had more in it.
The tq. Convert or is 9" but it is a cheap convertor from monster transmission.
I don't have any valve float and I rev it to 6800.
I notice revving that high that it didn't go any faster.
I am going to mess with jetting and remove some weight from the car.
I am getting a 1.80 60 ft. With no spin with the dragradials.
I may just throw 100 shot on it not sure if the motor with like it.
The exhaust is junk I think. Shorty headman with y pipe exit out side of car in front of rear wheel. Sounds good
Old Jan 19, 2017 | 11:30 AM
86LG4Bird's Avatar
Re: 1/4 mile times
1.80 60' tells the story.
If you want to optimize your NA performance, then as was said above, you need more stall for that cam. and a higher quality TC will help matters too.
But, for the 100 shot, leave the present TC in there; it'll flash that TC way beyond 3000.
Old Jan 19, 2017 | 11:35 AM
Car: 86 irocz
Axle/Gears: 4.10
Re: 1/4 mile times
Ok. I'm going to try to optimize the combo before I do the 100 shot. I'm going to track this weekend. I took little weight off car and I am going to jet carb. Should I start jetting up or down?
Old Jan 19, 2017 | 12:02 PM
midias's Avatar
Re: 1/4 mile times
Get something like this
https://www.amazon.com/AEM-30-4110-U.../dp/B00N3VGPYS
Install and it will tell you up or down. Or if you have a holley carb then follow the tuning sticky in the carb section.
Old Jan 19, 2017 | 12:36 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: 1/4 mile times
What intake manifold?
Old Jan 19, 2017 | 03:24 PM
Car: 86 irocz
Axle/Gears: 4.10
Re: 1/4 mile times
rpm airgap
Old Jan 19, 2017 | 07:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: 1/4 mile times
Have you checked plugs at all after a pull? Ideally a wideband will help tell rich/lean and give you a direction to go. What timing?
Old Jan 19, 2017 | 08:00 PM
Car: 86 irocz
Axle/Gears: 4.10
Re: 1/4 mile times
i have not checked plugs yet. the last time that i went to track the place was packed and i was just running as is. i will pull plugs this weekend at track and check. my timing is at 36
Old Jan 19, 2017 | 08:04 PM
Car: 86 irocz
Axle/Gears: 4.10
Re: 1/4 mile times
how does yours run?
