Where does this port lead to in the head?
Car: 86 Trans Am WS6
Engine: 383 stroker
Hey guys, I'm doing the fuel injectors on my 86 trans am 305TPI right now. I popped off the passenger side valve cover to gain access to the lower runner bolts and did a quick check and saw the port closest to the radiator has pieces of a cork valve cover gasket jammed up in it.
where does this lead to and about how screwed am I? Gonna use tweezers to remove what I can but I'm afraid some probably already made its way down the passage.
Trying to upload pics but it wont let me click the insert image icon, bear with me for a second.
Engine: 383 stroker
Re: Where does this port lead to in the head?
I know its out of focus but it's the passage right above the pool of oil.
Car: 87 iroc-z
Engine: 454
Transmission: th350
sure looks like an oil drain back hole to me. it drains back down into the lifter valley area.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Just an oil drainback hole. Even if there was a piece of cork covering the hole, oil will still find another passage to get back into the pan.
Engine: 383 stroker
awesome thanks guys, gonna remove what I can but won't worry about it too much.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Engine: 383 stroker
I haven't driven the car since July of 2016. I was pretty happy with how clean the rockers were. No gunk or sludge build up. Gonna give it an oil change once the spring comes around
Engine: 383 stroker
Car: '87 IROC
Engine: LB9
Figured that's the sitting/winter effect. I used to get that when I lived in Montana. Block heaters and cardboard in front of the radiator used to help in those -30F winters.
