Binding Gas Pedal: Stock Carb 305
Old Feb 18, 2017 | 02:50 PM
vincevs's Avatar
Car: 1982 Trans Am
Engine: 305 with a cam swap
My accelerator / gas pedal binds during travel down to the floor and won't return without manually pulling it back up. I cleaned up the carb and it has a return spring. At the carb, the linkage snaps back right away and fast so I'm pretty sure it is at the pedal... before I take it all apart I just wanted to confirm if there is a bushing or hinge point I should be replacing. Cheers!
Old Feb 18, 2017 | 05:19 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Binding Gas Pedal: Stock Carb 305
Here's a little info of what your dealing with.
Old Feb 18, 2017 | 05:33 PM
vincevs's Avatar
Car: 1982 Trans Am
That helps! Thanks!!
Old Apr 5, 2017 | 12:22 PM
vincevs's Avatar
Car: 1982 Trans Am
Replaced the pedal... it was a worn bushing where the pedal rod mounts to the body bracket. Gtg!
Old Apr 6, 2017 | 08:17 PM
Great.
Sometimes the pressure on the throttles from engine vacuum, will cause the carb to bind when the engine is running, even though it works fine when the engine is off. In that situation it's usually throttle plate bushing time, and maybe throttle shaft coating too.
