LG4 cam options
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
LG4 cam options
I know this has been asked time and time again, so I apologize for that. I am going to be pulling my LG4 out of my 84 Z28 to re-gasket it and have the heads freshened. What would be a good cam to go with while I have it apart and out. I was looking at a VooDoo cam 60100 that is 437/454 lift and 207/213 duration at 50 with a 112 LSA, or a H260 Comp cam with 440 lift and 212 duration at 50 with a 110 LSA. The car has headers, 2.5" Y pipe with the edelbrock exhaust system, no cat, no computer, summit intake, non CC q jet, aluminum water pump. It still has the factory T5 with 3.23 gears. any input on those cams or if anyone has a better suggestion that would be great. I am also looking at drive ability because the car is nearly a daily driver.
Re: LG4 cam options
Comp XE256
The Voodoo you list should also work well.
DO NOT use the 260 in a 305. You will regret it.
Car: 1983 G20 Chevy
Transmission: 4L60
Axle/Gears: 4:10
Re: LG4 cam options
I just installed Aerohead Racing prepared 601's and a Summit K1103 in my 85 Z28 5 speed. After 200 miles, I am totally impressed with the midrange of this cam. Another option is an Engine Pro/Speed Pro MC1988 or Comp Cams XE262H10.
Do a google search; "305 build"
Lots builds on the web.......Good luck
Axle/Gears: 4:10
Re: LG4 cam options
Super Chevy liked the K1103 as well.
http://www.superchevy.com/how-to/engines-drivetrain/1412-how-to-mod-a-305-with-bolt-ons-add-168-rwhp/
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: LG4 cam options
anyone have any opinions on summits K00052 for the same application?
https://www.summitracing.com/int/par...0052/overview/
Axle/Gears: 4:10
Re: LG4 cam options
I'm not a big fan of "square" cams, but it's probably a personal preference in our applications. Clearly, not too big for a 305 with a stick, but on the edge for a stock converter.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: LG4 cam options
All things being equal the single pattern grind will make more low-end torque because you can tighten the LSA and have less overlap.
