My Camaro Won't Shift Into Park
Old Feb 27, 2014 | 06:17 PM
Jakedog53c's Avatar
Car: 1983 Camaro Z28
Engine: 355 ci, Double-Hump Vortec Heads
Transmission: Stock T-5 Manual
Axle/Gears: Stock
Hi. My names Jake. I have a 1983 Camaro Z-28 with a stock 305 ci with Cross Fire Injection and a 4 speed automatic transmission. It won't shift into park. All the other gears work just fine. It goes all the way up. but it won't lock into park. It normally didn't go into park unless you let it kick into reverse for a few seconds. Now it won't go in at all. My emergency brake don't work other-wise I would use it. I could really use some help on this guys. Thanks for looking!! https://www.thirdgen.org/forums/images/smilies/help.gif
Old Feb 28, 2014 | 07:26 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Re: My Camaro Won't Shift Into Park
Have you checked your Park Lock cable that is connected to your shifter? See if there is any slack or if it has came off. If it's not the cable your most likely going to have to pull the trans pan and make sure the awl is engaging.
Old Feb 28, 2014 | 09:41 AM
Jakedog53c's Avatar
Axle/Gears: Stock
By park lock cable do you mean Detent Cable? Shift Cable? or what? Thanks for the reply
Old Feb 28, 2014 | 10:38 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
I would check the ends of the shifter cable (both ends) and make sure the plastic wings on the cable housing are not broken. Mine did that and the wings were broken off at the shifter where the cable housing goes thru the bracket just forward of the shifter. It allowed the cable to push forward while moving the lever to park. The cable housing should not move AT ALL.
Old Feb 28, 2014 | 11:22 AM
Jakedog53c's Avatar
Axle/Gears: Stock
Thank's for the reply. I will check this when I get home.
Old Feb 28, 2014 | 11:49 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Does the shifter physically not go into the "park" location or is the gear not changing into "park"?
Old Feb 28, 2014 | 12:01 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
I've gone through 2 shifter cables in the past year due to snapping, This happened after car started getting harder & harder to put in park, In my situation, there is a rubber grommet that I didn't have pushed in all the way at the opening where the cable goes though hole under car from under center console radio area (cuz it was a pain) & I think that's where I went wrong.
Old Feb 28, 2014 | 12:07 PM
Jakedog53c's Avatar
Axle/Gears: Stock
It physically goes Into park, the gear is not changing.
Old Feb 28, 2014 | 12:08 PM
Jakedog53c's Avatar
Axle/Gears: Stock
Okay it could be possible that I didn't get the rubber all the way in when I installed the shift cable. Thanks for the reply.
Old Apr 7, 2017 | 12:17 AM
Jayzo Jd's Avatar
I have an 1982 z28 crossfire it won't shift out of park stuck will not move any help will help out thanks
Old Apr 7, 2017 | 07:09 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Try putting the car into Park while jiggling the ignition key...I'm betting it's not adjusted properly, and you're running into the shifter locking mechanism that normally prevents the car from being taken out of Park without the key.
1992rs/ss
Jan 31, 2025 05:10 PM
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
