305 cam upgrade
Car: 2012 Impala ltz 1988 Gta project
305 cam upgrade
I am getting ready to drop a 305 into my gta for a year or two as i finish the car then build a new motor. Some good friends and family set me up with a weiand intake holley 600 carb and a Hei vacuum advanced carb. Also purchased a used but good quality headman headers. Redoing the gaskets and new timing chain. While i am at this point debating possibly dropping in a cam. My issue is this is the older block its an 84 block. Was wondering what people think. Should i drop a cam in and if so which one. Or should i just leave it where I am at. I would love to get to 200 hp at the crank but at the same time I know this motor will be coming out once the rest of the car is finished.
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: 305 cam upgrade
with the price of parts in the US, drop one in it. small investment for a year or 2 of more enjoyable driving.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 305 cam upgrade
Crane 100052 is what I would run. Summit cam kits unless they have changed do not have the best lifters included with them. I have run 268/272 grind cams in several 305 and 350 builds. They work with the stock torque converter and have plenty of idle vacuum for power brakes and vacuum accessories. They work with the stock compression ratio and build great midrange torque and horsepower. I would say even a LG4 would make 250 HP and 300 TQ at the flywheel with that cam, decent intake, carb and headers.
Car: 1983 G20 Chevy
Transmission: 4L60
