L98 with vortec heads question
I have a 91 l98 I want to install a mini ram and vortec heads. Can I use stock lifters,push tubes and rockers from the l98? If not what needs to be changed to install vortec heads?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: L98 with vortec heads question
Should beable to but should measure pushrods to be sure of length. If using a different cam then definitely measure pushrods
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Are the stock rockers self aligning? Vortecs need those
