Quick reply request: Oil Pressure Sensor?
Old Mar 14, 2017 | 10:36 AM
Ja85z28's Avatar
Axle/Gears: 4:10
Is this the only oil pressure sending unit on a 1985 Z28 LG4 ENGINE? It was located under the distributor and I am not seeing a second sensor near the oil filter. Please reply.
Old Mar 14, 2017 | 10:41 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Quick reply request: Oil Pressure Sensor?
Yep, single wire BRN/WHT
Old Mar 14, 2017 | 10:55 AM
Ja85z28's Avatar
Axle/Gears: 4:10
Thanks Bro
Old Mar 14, 2017 | 11:51 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Looks like yours is a basket case...
Old Mar 14, 2017 | 02:14 PM
Ja85z28's Avatar
Axle/Gears: 4:10
Patio furniture, but I am digging basket. It turned out to be the sending unit and not a spun bearing!!! Thank you Lord! I went ahead and install a tee and 1" oil pressure guage as cowitness to the dash guage.
Old Mar 14, 2017 | 05:18 PM
five7kid's Avatar
Yes, the oil pressure sender is a common failure point. Adding a mechanical backup gauge is a good move.
Old Mar 14, 2017 | 05:23 PM
Ja85z28's Avatar
Axle/Gears: 4:10
I was smiling like crazy when I seen that oil pressure at 40 psi!!!!
