1999 CAMARO 3.8L SMELLS LIKE BURNING ANTIFREEZE
Old Apr 17, 2017 | 08:09 PM
CINDYMILLER's Avatar
RADIATOR FULL WITH ANTIFREEZE, ALWAYS, DOESN'T GET OVER 210 DEGREES, RESERVE A BIT LOW HERE AND THERE. DON'T KNOW WHAT IT IS. ONE TIME ONLY THE RESERVE HAD APPARENTLY BUBBLED OUT AFTER I HAD BEEN DRIVING IT FOR 20 MINUTES OR SO. DIDN'T NOTICE IT UNTIL I WAS LEAVING WHERE IT HAD COME OUT AND KINDA STAINED THE DRIVEWAY. ANY HELP IS MUCH APPRECIATED.
Old Apr 17, 2017 | 08:21 PM
Drew's Avatar
Re: 1999 CAMARO 3.8L SMELLS LIKE BURNING ANTIFREEZE
You are on the wrong forum. Thirdgen.org is a site/forum for 1982-1992 Camaros and Firebirds only.
Old Apr 17, 2017 | 08:31 PM
OrangeBird's Avatar
Car: 1989 Firebird
Hi Cindy Miller ,
If you smell burning antifreeze from under the hood it is leaking and burning off on the hot engine , like maybe leaking onto an exhaust manifold perhaps . It only takes a tiny amount to be leaking and burning off to be fairly noticeable , smell wise , and it usually burns off before it gets the chance to drip onto the ground and leave obvious puddles (by then you've got a BIG leak instead of the small leak you've got now) .
What needs to be done is for a "cooling system pressure test" to be done , and when done properly that will pinpoint the source of the leak . Of course , it could be anything from a simple radiator hose replacement all the way up to something like a headgasket but hopefully usually it's something minor like the hose .
PS , just so ya know , this is a forum for third gen Camaro , 1982 to 1992 only , and if your thread gets closed it's because the mods here try hard to keep the content to 1982/1992 only .
Best of luck and here's to hoping your leak is a minor one !
Old Apr 18, 2017 | 12:52 AM
HEY THANKS SO MUCH FOR THE INFO. ALL OF IT. WRONG FORUM AND ALL.
APPRECIATE YOU ANSWERING ANYWAY.
GOOD PEOPLE.
SteamyShower
Apr 15, 2017 10:05 AM
Vinscully50
Apr 12, 2017 12:06 PM
1986_IROC-Z
Apr 5, 2017 06:14 PM
EPON
Mar 27, 2017 08:20 PM
EPON
Mar 19, 2017 08:09 AM
