Mystery plugs
Old May 1, 2017 | 05:43 PM
NZ84TA's Avatar
Car: 1984 Trans Am
Engine: LG4 305 4bbl
Axle/Gears: 3.23 LSD
Mystery plugs
I'm in the process of getting my LG4 back to original spec having got the original carb back from the previous owner which I will have rebuilt and a new CCV whih arrived last week. New Zealand Post did manage to lose the new purge solenoid though
But what are these plugs all about? Can't see where they're supposed to connect to for thr life of me. Are they related to emissions or options the car doesn't have? Anyone know?
Cheers
Old May 1, 2017 | 07:12 PM
Re: Mystery plugs
Unfortunately it runs off the edge of the screen.
And, I can't see what color the wires are. Seeing the connector isn't real valuable if you can't see the wires. All I can tell is, it's a 2-cavity Weatherpak, which in those years, were used exclusively for ECM-related things.
But, based on where it is, probably goes to the AIR diverter valve.
Can't comment on what options the car does or doesn't have.
Old May 1, 2017 | 07:34 PM
Drew's Avatar
Re: Mystery plugs
That's what I was thinking.
Old May 1, 2017 | 09:44 PM
NZ84TA's Avatar
Car: 1984 Trans Am
Re: Mystery plugs
Ok I'll get a better picture later tonight.
Car has headers so no EFE and no diverter valve but I'll double check that.
It's always run rich with a smoky start up that clears up eventually. My concern is something is telling the computer to richen the mixture (though I don't know if any of the smog gear is ECM controlled). This is why I figured on rebuilding and reinstalling the original carb and CCV and associated lines minus EFE and this diverter valve if thats whats those plugs are for. I also have a new EGR.
Old May 2, 2017 | 07:25 AM
NZ84TA's Avatar
Car: 1984 Trans Am
Re: Mystery plugs
More pics...
Possible original location of diverter
CCV
Old May 2, 2017 | 05:18 PM
Re: Mystery plugs
Yes the diverter valve went sort of behind and below the alternator. The fact that it's missing is why the alt belt is slightly misaligned. You can put a washer behind it to space it back out right again.
The grey plug also went to it. If memory serves, one is the vent-to-atmosphere control (the actual "diversion" function) and the other switched between delivering the fresh air to the manifolds or to the cat.
The soot/rich thing when cold may be as simple as, the choke vac break pulloff not being properly adjusted.
Old May 3, 2017 | 06:30 AM
NZ84TA's Avatar
Car: 1984 Trans Am
Re: Mystery plugs
Thanks sofakingdom. I'll be a happy man if it's just a maladjusted/faulty pull-off. it's the one thing that really bugs the hell out of me.
