Valve Spring Suggestions
Old Jun 14, 2017 | 10:21 PM
rottweiler68's Avatar
Car: '89 Iroc
Engine: 383 TPI
Transmission: Built 700R4
Axle/Gears: 9 Bolt - 3.45
Looking to replace stock valve springs while doing lifters/pushrods and can use any recommendations for which springs to get. Just trying to find comparable to the original stock ones (part # 03911068) or at least specs for them. This is for an '89 5.7 TPI
Old Jun 14, 2017 | 11:13 PM
GeneralDisorder's Avatar
Re: Valve Spring Suggestions
https://m.summitracing.com/parts/nal-19154761/overview/
You can also do 1.6 rockers for some extra lift. They are a bolt on with no modification required. I got Comp cams roller tip 1.6 rockers and did these springs, and new stem seals. You will need the self aligning rockers for the 89 heads.
GD
Old Jun 14, 2017 | 11:21 PM
Car: '89 Iroc
Engine: 383 TPI
Cool thanks again!
For lifters are these any good? Again just looking for comparable to stock.
https://www.ebay.com/itm/252640122087
Old Jun 15, 2017 | 09:52 AM
I would choose these vs the unknown. Melling is a respected name:
http://m.ebay.com/itm/SBC-CHEVY-V-8-...%257Ciid%253A2
GD
Old Jun 15, 2017 | 09:59 AM
Car: '89 Iroc
Engine: 383 TPI
Great info thanks again!
