Installing A/C
Old Jun 30, 2017 | 12:01 PM
CMAN84's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383 stroker crate engine
Axle/Gears: 373 posi
Installing A/C
ok guys I figured ill make a post before I head into work so if I don't respond for 8 hours, thats why lol. so, I have an 84 z28. when I installed a crate motor, I cut out a lot of wires, I kept only those that were needed to run the engine. with that, ac wiring was cut and the factory cooling fan wiring and added electric fans to a toggle. I have since converted over to a serpentine from a v-belt and decided it was time to put ac back in. I know the wires for ac are still in the car somewhere and another member has already showed me a factory 84 wiring harness. I have already installed the compressor, condenser, lines, blower housing, drier and the only wires that I found were the wires that plugs into the drier. my question is, what wires do I actually need to make it work? I know ill need the wires that connect to the front of the compressor but other than that, I'm clueless. I'm a dummy when it comes to wiring lol. any info would be so helpful! thank you in advance!
Old Jun 30, 2017 | 07:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Installing A/C
Take it to a shop that knows how to do it properly. Someone leading you blindly when you have no idea about wiring isn't going to help you.
