Mystery connector
Car: 1988 iroc-z (original owner)
Transmission: 5-speed manual
Mystery connector
While working on the 1988 LB9 rebuild, I thought that this is a good time to buy replacement senders, sensors, and switches. I recalled that when i was prepping the engine to pull it, i ran across a lead for which the connector is mangled and i couldn't find its mate anywhere down under. It is a single black wire. It exits the "starter loom" with the detonation sensor and starter leads having the fusible links. I cannot find it the service manual--I may figure it out after installing the engine, but I want to buy these items beforehand. So what is it? (the knock sensor is on the right in the attached picture)
as always, thanks in advance.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Mystery connector
It could be the temp sensor in between 6&8 cyl in the head.
i'll check the old one. i just thought that if it exited with the knock sensor et al, then it must have been something running low to the frame.
thanks
thanks
