spark plugs
Old Jul 10, 2017 | 10:57 PM
villale1's Avatar
spark plugs
1991 Camaro Z-28 5.7L
Which spark plugs should I buy?
Old Jul 11, 2017 | 01:52 AM
GeneralDisorder's Avatar
Re: spark plugs
ACDelco is a safe bet.
GD
Old Aug 2, 2017 | 09:17 PM
I rock 88's Avatar
Car: 1989 RS Black Vert
Engine: 305 TBI
Axle/Gears: 2:7some thing
Re: spark plugs
If you have an owners manual look in there it will give you the name and the number of plug you should use in your car Chevrolet has spent thousands of dollars to figure this stuff out I would bleave they have done all the research and have the right information
Old Aug 2, 2017 | 09:23 PM
wilmil's Avatar
Car: 83 Pontiac Trans AM
Engine: 305 CFI
Re: spark plugs
There's a lot of variables there. Is the car stock? Many performance modifications?
If it is stock, AC Delco R45TS or NGK 6630's are a safe bet.
Old Aug 4, 2017 | 10:31 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: spark plugs
Assuming stock, OEM Delcos are a safe bet. But if your car is running correctly, NGK Iridiums will give you about twice as long between changes, they do seem to foul more easily if the car isn't running well.
evlbeak
Oct 29, 2016 10:43 AM
evlbeak
Oct 28, 2016 02:07 PM
Culdee
Oct 26, 2016 07:55 PM
GypsyMuscle
Sep 22, 2016 07:53 PM
vortech305
Aftermarket Product Review
May 18, 2001 05:48 PM
