mechanical fuel pump removal
Old Jan 2, 2002 | 12:09 AM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
Last winter, i swapped over to TPI from a carp and didnt use the mechanical fuel pump anymore. I left it on the engine though, and its just sitting not doing anything. THis winter, im pulling the engine again to freshen it up a bit with a new cam and intake, and i removed the pump and plate just to check things out. I noticed that the pump requred a lot of force from the pushrod, and i was wondering if removing the pump and replacing it with a blockoff plate would free up some hp? Now, im not expecting much, but ive heard of 50 hp gains just from doing a bunch of little things when rebuilding, like porting oil holes, etc.. .
What do you all think?
Old Jan 2, 2002 | 11:06 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Sure, it has to use some amount of HP to run a mechanical pump...maybe 1/2-1hp...nothing you'll feel, but no use running it if it's not needed.
There is HP to be freed up inside a block, how much depends on the level of work you have done. The 50HP you've heard of would seem pretty high, maybe you were looking/reading about balancing and blueprinting? to free up addition HP?
Old Jan 2, 2002 | 03:50 PM
Car: 82 Trans am
The 50 hp (or so) gains are from some serious internal engine work, balancing, drilling the crank journals, shaving counterweights, highly polishing the bore surface, etc. Not anything i would really need to do as an amateur, but i thought at least the pump would be a start.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
