Squeeky Puzzle...
Old Jul 24, 2017 | 12:49 PM
Chuck's Avatar
Squeeky Puzzle...
Serpentine belt squeeks for 5 minutes of so after start-up.
So heating up quiets things.
When I turn the steering wheel - power steering pump needs to work - and
squeek stops or minimizes.
If I spray the belt with water, squeek stops for 30 seconds or so.
That makes me think it is not a pulley bearing.
Belt dressing, however, makes it much worse.
Any ideas?
Also - I can't seem to tell where the squeek is coming from.
Tried the "stethoscope" but still not sure.
Any ideas on that?
Thank you!
Old Jul 24, 2017 | 12:56 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Squeeky Puzzle...
Have you removed the belt and spun the tensioner pulley ?
Old Jul 24, 2017 | 03:31 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
^ Agree, check the tensioner first. Also while it's running check for any pulleys which are wobbling. If all that looks OK, you may want to check the pulley alignment. They make special laser tools which sit down in the ribs to check alignment, but you can also just take a piece of straight bar stock and lay it flat against various pulley surfaces to get an idea. I had a recurring squeak that didn't go away until I shimmed the alternator pulley to be more inline with the others.
Old Jul 26, 2017 | 12:41 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Buy a new belt or tighten it.
