Valve train/cam chatter?
Old Jan 2, 2002 | 08:31 AM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
I have a '88 IROC w/ a 350 TPI engine it and its been running great till this morning. It has over 150K miles on it and it is not raced or abused. This morning I started up my car, it was 33 degrees outside, engine starts with no problem, oil pressure was good, climbed to about 55 PSI. After about a minute or 2 sitting and letting it warm up I started hearing this chattering coming from what sounded the like th middle of the engine and from under the valve cover on the pass. side. I revved it up just a little and it would get worst as it revved up. It was not the water pump or power steering pump. I thought it might go away once it warmed up but it never did. Has anyone had this happen to them? I checked my oil just like 2 days ago and it was fine and I guess I should have checked it this morning but I needed to get to work. I have a 355 shortblock waiting to be built up so I figured if it blew up, just a better reason to get the 355 finished!
Old Jan 2, 2002 | 11:29 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
could be the oil just drained from those lifters
Give it a good long drive and see if it quiets down.
Old Jan 2, 2002 | 12:19 PM
Engine: LS1 V8
I talked to a friend in my car club, he said it is probably my timing chain. He asked does it sound like a set keys kinda clanging and scraping and yeah it does. He has '92 RS and has already had to put a new one on his so I am going to pick a double roller chain today and put it on this weekend. My timing cover needs to be re-sealed so might as well do it.
Old Jan 2, 2002 | 03:13 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
be prepared - oil pan must be dropped a little
to remove the cover. You also need to have remove the harmonic balancer and crank shaft gear.
Also, very seldom does a T-chain all of a sudden start making noise. Its a long term gradual thing. Factory chains are normally coated on the top gear with nylon. They don't make noise even when they are worn out most the time.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
sleprock
Sep 24, 2015 04:33 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
