what is this?
Old Jul 28, 2017 | 09:24 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
what is this?
I'm under my dash to replace my heater core and I see this. its something vacuum controlled and from the looks of the vacuum boot it doesn't work right now. I'm going to replace that boot but I don't even know what to ask for. anyone know what this is? under dash by ecu
Old Jul 28, 2017 | 10:57 PM
Drew's Avatar
Re: what is this?
Its one of the vacuum valves that control the HVAC doors.
Old Jul 29, 2017 | 11:33 AM
Evilokc's Avatar
Engine: tbi 305
Re: what is this?
my a/c is working but it does take a bit longer to switch vent locations than I think it should. I will replace it and hope that makes it better. maybe I can get everything under the dash freshened up while I'm in there for the heater core. because I DONT want to go back under the dash if I can help it.
Old Jul 29, 2017 | 01:48 PM
Drew's Avatar
Re: what is this?
I'm not really seeing a problem in the photo. The doors inside the HVAC box tend to get sticky from leaking heater cores that were never cleaned up, rust, the foam rubber turning gooey and sticky from age, and so on. Slow response could be from any of the above, or a slow vacuum leak.
Old Jul 29, 2017 | 07:59 PM
Evilokc's Avatar
Engine: tbi 305
Re: what is this?
if you look close at the boot at the end of that vacuum hose its ripped. I'm sure I have a vacuum leak here. Its the boot on the end of the orange vacuum line on the a/c that connects to the recirculation diaphragm.
