Is this the right distributor for my car?
Old Aug 1, 2017 | 02:52 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
I've got a 1991 L98.
I found this.
http://performancedistributors.com/p...-distributors/
If I select "1987-1993" I get SKU 12620BK. Is that the correct distributor for my car?
Does anyone have any experience with DUI distributors? This is $75 cheaper than a rebuilt delco part. I heard their ignition control modules produce more power, but are prone to failure, so I'll probably swap that out for a stock unit.
Old Aug 1, 2017 | 10:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Is this the right distributor for my car?
Link is no good.
A stock control module can easily provide enough spark to spin an engine over 7000 rpm.
Inexpensive distributors are just like every other inexpensive part. They're usually inexpensive for a reason. Even OEM distributors will eventually wear out but are built to last much longer than inexpensive replacements.
If you want a good quality distributor, buy something like one from MSD or drop in an OEM.
Old Aug 2, 2017 | 12:15 PM
wgripp's Avatar
Please try this link and select Chevy V8, 1987-1993 from the stop down menu. I would like to know if this is the right one for my car.
Alkyiroc, thanks for your response. I hear you loud and clear. But, I've read questionable reviews about MSD nowadays. I'd go stock, but i can't find new AC Delco distributors, only rebuilds with recycled ignition control modules (ICMs) which often require replacement out of the box. I haven't seen anything negative about DUI (the product in the link), except that their aftermarket ICMs suck. They appear to be a quality manufacturer, otherwise. So I would like to buy their distributor and install a new stock ICM, if I can.
Old Aug 2, 2017 | 06:45 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If you are interested I've got a nice clean and solid used OEM on I picked up a while back for a potential spare but don't think I still need. Get me and email address for pics and info if you want
