Should I replace my older Edelbrock Water Pump?
Old Aug 4, 2017 | 10:46 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
So I am doing my timing chain and took off an Edelbrock water pump. No play on the impeller shaft and seems to spin fine. I am pretty sure it was put on in 2003 15-20,000 miles ago.
I have a new $35 AC Delco OEM pump coming but dang, the Edelbrock pumps seem to cost $200 so maybe I should just keep rolling with it.
Old Aug 4, 2017 | 12:47 PM
GeneralDisorder's Avatar
Re: Should I replace my older Edelbrock Water Pump?
I would just keep using it. Edelbrock has a rebuild service also.
15-20k is nothing. Should last at least 100k if the coolant is clean and maintained. The mechanical seals rely on good coolant.
GD
