89 iroc won't always start
Old Aug 5, 2017 | 11:01 PM
Jon Paul's Avatar
Having trouble starting my manual transmission car. Have tried replacing battery, starter is good. Should also point out that there is a Viper alarm system. Seems that it starts sometimes when you jiggle the key in the ignition and pump the clutch. Any suggestions would be appreciated.
Old Aug 6, 2017 | 01:23 AM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Re: 89 iroc won't always start
Jiggling key- is your VATS system acting up? What exactly happens when you turn the key and the car "doesn't start"? Anything?
Old Aug 6, 2017 | 01:38 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
You probably have a cracked vats wire that runs into your ignition tumbler. When you turn the key do you get power to everything but the starter just doesn't crank?
Old Aug 6, 2017 | 08:28 AM
Jon Paul's Avatar
Yes got power to everthing else just will not start.What can I do to fix it
Old Aug 6, 2017 | 10:03 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Does the starter turn the engine over?
You will need to replace the ignition/ key tumbler in the steering column. There is 2 little white wires that connect to the tumbler that wear out over time and every now and then you can't start your car because the Vats enables
