Part # old school 327 to 700r4.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Part # old school 327 to 700r4.
A flex plate from a 85 camaro would work. It's for a two piece rear main seal sbc 153.
Car: 1983 G20 Chevy
Transmission: 4L60
If the block has staggered bolt holes I would use a flexplate for a 85 G20 van and matching 168 tooth starter for a 1997 Express van. It is a factory permenant magnet gear reduction starter that is lighter and smaller than the stock starter. The larger flexplate and gear drive will keep it from having the typical hot start problems performance engines are known for.
