Finding TDC for all pistons so I can do rope method for valve stem seal replacement
Old Aug 25, 2017 | 10:12 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I zealously removed all of my rocker arms and pushrods and bagged them so now I realize I need to know which pistons are at TDC so that I can use the rope method (I can't watch the rocker arms).
So I have my damper index wheel on the damper and I need to know the pistons at TDC at 0, 90, 180, and 270. (clockwise rotation facing damper)
From the firing order:
I know 1 is at TDC at 0 degrees, would 6 be also?
So this is what I think:
0 deg: 1 and 6
90 deg: 5 and 8
180 deg: 4 and 7
270 deg: 2 and 3
Old Aug 25, 2017 | 10:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Finding TDC for all pistons so I can do rope method for valve stem seal replaceme
I think you're making a lot harder than it needs to be.
With all the rockers off and all the spark plugs out, the engine should bar over by hand very easily. If you have rope in the #1 spark plug hole to change the valve seals, the next piston coming up on the firing order will already be at least half way up the cylinder.
You can either just do one cylinder at a time simply moving down the bank or use 2 ropes to get both cylinders as they reach TDC. Since the valves are not opening and closing, it doesn't really matter which cylinders you do in any order just as long as you do them all.
Old Aug 26, 2017 | 12:03 AM
Engine: 350 TPI L98
Transmission: WC T5
Hah! Very likely!
Old Aug 26, 2017 | 01:16 PM
You are correct: #1 & #6 come to TDC together.
Line up the timing mark. At that point, #1 & #6 are at TDC. Do those 4 valves.
Turn the crank 90°. The next ones in the firing order, #8 & #5, are now at TDC. Do those 4 valves.
Turn the crank 90°. ...
1 6
8 5
4 7
3 2
Looks kinda like the firing order split in half into 2 columns, no?
Pretty straightforward, really.
Old Aug 26, 2017 | 06:11 PM
NoEmissions84TA's Avatar
Make sure all of your spark plugs are removed.
Don't remove all of the valve springs at once!
Because if you were to rotate the crank with this scenario,
a vacuum would be created in the cylinder. And...........
Your valves will disappear faster than you can say, "OH SH*T!
