Pesky Freeze Plugs.....
Old Aug 27, 2017 | 10:22 PM
jberry12's Avatar
Car: 88 Camaro, 95 OJ White Bronco
Engine: 305, 302 respectively
Okay, so the 88 Camaro sat under a covered parking area for 9 years. Should have been a clue. Replaced front pass side under the motor mount about 4 months ago. Then 2 weeks ago the driver side rear by the oil filter. Friday? The rear pass side behind the starter. Hardest part was getting the starter back in without lowering the exhaust.
Initial look.
Draining it out.
Lots of icky rust. Pulled out about a pound of it. Tried to clear out as much as I could reach.
Old Aug 28, 2017 | 11:16 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Pesky Freeze Plugs.....
Thats the result of using water instead of antifreeze/coolant !
I saw that MANY times when I lived down south!
NEVER seen a rusty block/radiator/bad freeze plug up north where
ALMOST everybody uses antifreeze/coolant.
Old Aug 28, 2017 | 02:25 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Because all the core plugs are the same age and condition (except the ones you have replaced so far), expect to replace all the old ones at some time in the near future.
Don't forget the ones on the front and rear of the block.
