1995 Chevrolet 1500
1995 Chevrolet 1500
I have a 95 Chevy 1/2 ton with about 190,000 miles. The truck uses oil (about 1 quart every 500 miles.
I use NAPA 10w30 oil.
I can't see any smoke when I start the pickup and it doesn't seem to smoke when I drive. I do notice a few leaks when it's parked, but it seems like the puddles should be larger if I'm using 1 quart per 500 miles.
I put STP stock leak it a couple of times, and that really helped.
Any thoughts are appreciated.
Car: 89 Firebird
Engine: 355 TBI
Re: 1995 Chevrolet 1500
Keep it full of oil and be starting to plan a rebuild or replacement. May last a long time if you keep it full of oil. I would go with a heavier 10w40 or even 20w50 at this point. Probably leaking at the rear main seal if I were to guess.
