What are these two things???
Old Sep 2, 2017 | 03:01 PM
Drew Morgan's Avatar
Car: 89 RS LT1 Swap
Engine: LT1 5.7L
WTH are these two things? Are they vacuum related? I'm pretty sure it's emissions related but I'm stumped!
Old Sep 2, 2017 | 03:44 PM
Re: What are these two things???
The one closer to the A/C accumulator is the AIR diverter valve, and is an emissions thing. The one behind the compressor is the heater control valve.
Old Sep 2, 2017 | 03:48 PM
Car: 89 RS LT1 Swap
Engine: LT1 5.7L
Thanks man! Other than the little vacuum line running to the heater control, would either of these cause any vacuum loss issues?
Old Sep 2, 2017 | 03:53 PM
Not really.
Old Sep 2, 2017 | 04:38 PM
Car: 89 RS LT1 Swap
Engine: LT1 5.7L
Thanks man!
Old Sep 9, 2017 | 10:51 PM
Marc Webber's Avatar
Car: !982 Trans Am
Transmission: 350 Turbo
Axle/Gears: 3.08
What would happen if a car didn't have a heater control valve
Old Sep 10, 2017 | 02:15 AM
nova983's Avatar
Car: 1988 Trans Am GTA
Axle/Gears: 3.70
the hot coolant would always cycle through the heater core. Meaning that you wouldn't have cold air as an option only hot.
Old Sep 10, 2017 | 09:23 AM
Car: !982 Trans Am
Axle/Gears: 3.08
That explains a everything. Thanks for the info. Thats why my air isn't quiet right.
Old Sep 10, 2017 | 10:43 AM
Twin_Turbo's Avatar
You would have cold air just not as cold as with a heater valve. The blend door regulates cold or hot air coming in. Plenty of cars came without a heater control valve... non ac ones and 82 83 (84?)
Old Sep 16, 2017 | 04:24 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
All of my cars never had a heater control valve...2 84 z-28''s H engines and a G engine 84 tran am...AC worked great inall of them
Old Sep 16, 2017 | 04:42 PM
Yup, my 83 as well; but, it worked noticeably better when I put a control head with that vacuum port, and a heater control valve, in it.
"It works great" is not the same thing as "it's as good as it can possibly be". Which is not to say, you're wrong, in either case; only, that change and improvement, often only come in small increments. But over time and enough of those little increments, there can sometimes be VAST differences. For someone as old as me, who remembers throwing stuff at his lunch as it ran by to slow it down long enough to take a bite off of it before it had a chance to bite back, .... some of these things can be a bit amazing.
