fuel delivery options i have, whats my best route?
Old Sep 14, 2017 | 11:13 PM
Robert Stack's Avatar
Car: Camaro Sport coupe
Engine: LG4
Transmission: overdrive auto> want a 5spd
I've got an 86 sport coupe that had the 2.8 EFI (that's important because the lines current plumbing is for that) I bought it mid tear down so the motor was already half out. bought a wrecked 83 Firebird "350" that i should have looked at a bit closer i know they didn't have those stock in 83 but people do swaps all the time.... look at what i'm attempting, any way, another story for later. my question is should i run the hot wire from the electric fuel pump the v6 used to an accessory fuse, and use a fuel pressure reg so not to blow out my carbs seals or old style sending unit and re-plumb my fuel lines to the block mounted pump?
Old Sep 15, 2017 | 05:57 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: fuel delivery options i have, whats my best route?
I did a 385 swap into my v6 car in the spring here is what I did.
Left the ecm intact. So anytime i turn the key on the fuel pump still primes and so forth. Left the oem relays as well.
All I did is buy a Holley regulator that was made to accept up to 60 psi supply and knock it down to 4 5 6 7 psi or what ever you will be running with a carb. The cheapest one I could fine was the holley and it cost like 130 bucks. But it works flawless.
The 3/8 supply line is way more then enough to supply 500hp 600hp easy when it's at the stock 42.5 give or take pressure. I ran 6an line out of the regulator to a dual feed Holley 750 carb. I run mid 11s and never had any issue maintaining fuel pressure. The regulator also is a return style so you'll hook it to your stock 5/16th inch return line as well.
If you can zoom in the bottom pic you can see the regulator.
Also I've ran a walbro 255lph pump for many many years in the car.
I took a Turbo v6 and swapped in this v8 in like 8 hrs of work. Very easy to do exspecially if your k member had the holes for the v6 and the v8 mounts. All you do is remove the v6 mounts and then bolt on the v8 ones.
Old Sep 15, 2017 | 06:43 AM
Engine: LG4
yea the mounts from the donor car fit perfectly love that gm pretty much drilled all the holes for every possible application they offered, im wondering why i dont get my prime then when i turn the key. thats a new line of thought ill have to explore. i appreciate that. (side note the motor mount bolts on the sub frame were a pain... ended up using fishing line and the bolts are upside down)
Old Sep 15, 2017 | 08:43 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Yea it's hard to change the mounts with the arms and springs on there. Pita!!!
Did the previous owner mess with the stock wiring?
