24x / stealthram no power?
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
I finialy got my 24x conversion done and a holley stealth ram on, the car is tuned( my tuner screwed up i believe) the car runs ok but has no low end torque at all, less then with the factory tpi, it wont even break the tires free, it has a hard time getting to 2500 rpm but once its there and past its a rocket, it also used a full tank of gas in 60 miles! What the hell is going on?! The car has a 92 crate 350 with l89 heads on it, it should be making decent power, is it my engine or do i need to get it tuned again? Also, the tuner didnt delete any dtc's it has 12 emission related codes along with maf code that the car doesnt even have, i dont know what else to do
any help/ advice would be greatly apprieciated!
any help/ advice would be greatly apprieciated! Supreme Member
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: 24x / stealthram no power?
I believe you've answered your own question; it needs a proper tune before you run it any more at all. Hopefully you've not already destroyed the ring seal by washing down the cylinder walls with excess fuel.
Car: 1983 G20 Chevy
Transmission: 4L60
Tuner should have gone to a custom MAP only operating system or you need to add a MAF in. I prefer staying with the MAF because they work really well and the driveability is better. It sounds like the tuner screwed up. I bet if I were to look at the tune I would find numerous things wrong with it.
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
I wouldnt be suprised, its definately not right thats for sure. Well i guess back to the tuner it is, its a challange to find a reputable place where i am if you can find one at all
