change thermostat on my 305 v8
Old Oct 6, 2017 | 07:38 PM
larry88ttops's Avatar
Car: 1988 Camaro w/T Tops
Engine: 305 TBI
Transmission: Borg-Warner 5 spd
1988 Camaro TBI V8
Old Oct 6, 2017 | 09:08 PM
GeneralDisorder's Avatar
Re: change thermostat on my 305 v8
Yes! Yes you absolutely can change the thermostat. Go ahead you have our permission.
GD
Old Oct 6, 2017 | 09:46 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Lmao
Old Oct 6, 2017 | 11:58 PM
Engine: 305 TBI
Yeah - I know this came off as kinda lame! I have changed the cam, the heads, the intake, the chip, the rear end gears, modified the TBI, installed headers and a cat back - lots of stuff to this car in the past 17 years. But here lately, I've had this pesky leak right around the thermostat housing and it's driving me nuts! I've changed the thermostat a couple of times and tried several methods and types of gaskets. What I'm going to do tomorrow is take the hold down screws out and give them a good coating of Form-a-Gasket, as I suspect that they screw down into the water jacket. That was why I was asking about the procedure, to see if this was the case.
So let the sarcasm continue - just be gentle!
Old Oct 7, 2017 | 12:09 AM
Drew's Avatar
Pull the intake to head bolts in that corner. Clean the threads and use thread sealer.
Old Oct 7, 2017 | 12:16 AM
Engine: 305 TBI
Thank you, sir!
I am looking for any ideas here!
I will do this in addition to pulling out the hold down bolts and smear sealer on everything!
Old Oct 7, 2017 | 07:32 AM
Replace it.
http://www.autozone.com/cooling-heat...848184_13975_0
The one for your car probably costs about the same.
Gunsbee
Nov 12, 2017 10:57 AM
zeitghaist
Aug 18, 2017 03:18 AM
phasevariance
Aug 7, 2017 03:40 PM
Evilokc
Jul 30, 2017 10:14 AM
Camaro-3
Jul 11, 2017 02:37 AM
