Stalling at idle -87 IROC 350
Old Oct 21, 2017 | 07:11 PM
Chefobrien's Avatar
My situation with stalling has improved. We have replaced the MAF, distributor timing was corrected by mechanic, no vaccum leaks that can be found, ignition coil is working. Since the distributor timing was corrected she has not stalled on me while driving, but still acts up when in idle in the driveway. Here is video, you can fast forward about 20 seconds to see when the issue starts. By the way, when I start her back up, there is no Service light, MAF code has cleared since I replaced it. Thanks!
Old Oct 22, 2017 | 09:57 AM
Vader's Avatar
Re: Stalling at idle -87 IROC 350
If there are no other error codes stored, read about what the error code 12 actually means. HINT: It does NOT mean "service mode" or something similar, as many people seem to believe.
