82 Camaro 2.8 carburated has spark/fuel won't run
Car: 1982 Camaro Sport Coupe 2.8l
Engine: 2.8l code 1
Transmission: auto
I am at my wits end and wonder if anyone can help, I have a 1982 Camaro Sport Coupe 2.8l carburated that I recently acquired and is my only vehicle atm. When I bought it I replaced the fuel pump, alternator, rebuilt the carb and installed new plugs. The car ran absolutley perfect! Midnight Christmas morning while doing 65mph with no issues the engine suddenly "popped" a few times and shut down (sounded like from the exhaust). I've since towed the car home, upon inspection I find I have spark and fuel yet the engine just spins without firing. All fuses in the panel check out good, battery is a a little tired but I have it on a charger/booster while running diagnostics. Could it go from running perfect (starting with the first bump of the key) to losing compression like a toggle switch? I am assuming it's not timing chain related since if the distrib. wasn't turning I wouldn't have spark, and all the plugs look normal. Any thoughts would be appreciated and thanks in advance.
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: 82 Camaro 2.8 carburated has spark/fuel won't run
Unless you have beautiful blue spark, Replace coil cap and rotor
Engine: 2.8l code 1
Transmission: auto
I did notice the spark was yellowish, will give that a shot, thnx, will respond with result
Engine: 2.8l code 1
Transmission: auto
You sir deserve a medal, meanwhile I deserve a slap in the head for failing to suspect something so simple. Upon changing out the cap and rotor, the center contact on the rotor was completely disloged (making me wonder how I was getting any spark at all) also the cap had considerable corrosion/oxidation were the plug wires connect. New rotor/ new cap boom, purring again. Thank you very much W.E.G.!
Engine: 2.8l code 1
Transmission: auto
This issue has been resolved...cap and rotor were junk. don't know how to delete this posting, sorry for posting it twice.
junkie
Apr 26, 2002 07:55 PM
