What determines a hose needing a clamp or not?
Old Dec 31, 2017 | 03:11 PM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
I was just wondering today as I was replacing vacuum hoses and vapor hoses for the charcoal canister...how does GM determine if a hose needs no clamp, a cheap spring clamp or a screw clamp for the smaller hoses? I was thinking maybe fuel hoses got the screw clamps, vapor hoses got the cheap spring clamps and vacuum-only got no clamps at all (if they fit really tight) but the canister hoses are like half and half and some of my vacuum-only hoses do have clamps. I would think every hose would get some kind of clamp but that obviously is not true on my oem tbi setup.
Old Dec 31, 2017 | 03:21 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: What determines a hose needing a clamp or not?
If the line pulls vacuum, it generally does not need any clamp force to retain
On a turbo car, where systems see positive manifold pressure, many connections are secured w clamps.
So under pressure, clamp. No pressure or vacuum, clamp. How much, depends on what's used.
Old Jan 1, 2018 | 12:38 PM
GeneralDisorder's Avatar
Basically what he said.
I will add that these are THE professional way to clamp boosted application vacuum lines:
https://www.amazon.com/Oetiker-Stepless-OET070170-300PCK-Assortment-without/dp/B00QK3V4PG/ref=pd_sim_328_2?_encoding=UTF8&pd_rd_i=B00QK3V4PG&pd_rd_r=S7TN3Q608V73PDS86466&pd_rd_w=a08ty&pd_rd_wg=G2dkk&psc=1&refRID=S7TN3Q608V73PDS86466 https://www.amazon.com/Oetiker-Stepless-OET070170-300PCK-Assortment-without/dp/B00QK3V4PG/ref=pd_sim_328_2?_encoding=UTF8&pd_rd_i=B00QK3V4PG&pd_rd_r=S7TN3Q608V73PDS86466&pd_rd_w=a08ty&pd_rd_wg=G2dkk&psc=1&refRID=S7TN3Q608V73PDS86466
And you want 50psi rated silicone also. XRP in California is our supplier. Very reasonable for bulk 50psi rated vacuum line.
GD
Old Jan 1, 2018 | 12:45 PM
I would add also that the "cheap" spring type clamp is WORLDS BETTER than the worm gear type in most situations; not least because, it's impossible for it to lose clamping tension by way of the hose material compressing underneath it and causing a leak. Too bad they can be such a PITA to get on and off during service.
Old Jan 1, 2018 | 10:45 PM
Drew's Avatar
Most vacuum lines aren't under enough pressure to be a problem. Even on a boosted application, if small diameter vacuum line is properly sized to the barb it's pushed onto, it's not going to blow off without a clamp.
Boosted 23psi in my Mustang, and I don't think that car has a single vacuum line under 3/8" diameter with a clamp on it. Blew the silicone coupler and T-bolt clamp off the throttlebody one time, but have never blown a reference line.
Old Jan 3, 2018 | 03:18 PM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
Good info thanks guys!
buffetfn1
Exterior Parts Wanted
Jul 27, 2015 05:36 PM
Ron U.S.M.C.
Aftermarket Product Review
17
Jul 26, 2015 10:26 PM
travisnd
Aug 15, 2008 12:59 PM
GTAlover
Jan 16, 2005 02:11 AM
pescobar456
May 1, 2002 05:46 PM
