hose clamp embarrassing question
Old Apr 30, 2002 | 03:44 PM
pescobar456's Avatar
Can't get the hose clamp off the coolant hose to my throttle body! The hose clamp isn't the usual steel worm drive I'm used to seeing. There is a raised hump that a screw goes into, I think it's called a tower clamp. Unscrewed but the clamp isn't loose? Not sure how to take off this hose clamp. Help please.
Old Apr 30, 2002 | 04:01 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Tell me your real screen name, and I'll tell you the secret
Old Apr 30, 2002 | 05:41 PM
85wilrocu's Avatar
huh!
Old May 1, 2002 | 11:24 AM
Can anyone help me please?
Old May 1, 2002 | 11:35 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I hate those *** damn things! Basically what your have to do is loosen the screw as much as possible, then work the clamp loose. Most likely you will end up bending the crap out of it to get it off. It will take a while but keep working with it, it will come off. Then replace it with the good ol' fashion hose clamp.
Good luck!
Old May 1, 2002 | 01:53 PM
gruveb's Avatar
Car: 1989 IROC-1
CraZ-28 is right. Those things are terrible to remove!
You'll just have to work at it to get it off. Don't fret if you destroy it!
Old May 1, 2002 | 04:44 PM
rezinn's Avatar
Just back the screw out and have at it with some pliers and a screwdriver. Break it.
Old May 1, 2002 | 05:46 PM
iroc5speed's Avatar
seriously, those things aren't more than $1 each anyways
1992 Trans Am
May 10, 2023 07:19 PM
MintWS6FORMULA
Oct 19, 2015 08:53 PM
1985chevydude
Aug 22, 2015 05:36 AM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
