Input on PRW Sportsman Rockers for a budget build.
Car: 1992 Camaro RS
Engine: 305 :c
Transmission: t5
I hate to start yet another thread but I cant find a whole lot on PRW stuff, most of what i can find is just people hating on them because they are cheaper/chinese. Im still a senior and only working part time so im on a pretty tight budget with this build so I cant go out spending $400 on a set of rockers. Im looking at the prw sportsman series 0835021. Anyone whos had experience with these (or any prw products) id love to hear your opinion. Thanks
Re: Input on PRW Sportsman Rockers for a budget build.
First of all, those aren't self aligning, which you will need. Also they aren't significantly cheaper than the Comp roller tip 1.6 rockers. I got my Comp set for around $160
GD
GD
Car: 1992 Camaro RS
Engine: 305 :c
Transmission: t5
Ive got to use non self aligning for my heads due to the oversized valves, ill use guideplates. And I cant find any comp magnums in a 7/16 stud, id really prefer to upgrade to a 7/16 over the 3/8.
Car: 1992 Camaro RS
Engine: 305 :c
Transmission: t5
Call comp and ask them. They make pistons out of aluminium so it really depends on the alloy. If Comp makes it and says it's for street - their word is pretty good IMHO. They have proven their products to me and many others around here.
GD
GD
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
This motor is going in my daily driver so aluminum fatigue in the aluminum rockers kinda scare me. Im thinking maybe going with the comp magnum roller tips and just picking up a set of ARP 3/8 studs. I was just planning on going with 7/16 since I was buying new rockers/studs anyway, but i doubt ill ever spin it past 6200 so the advantages will be negligible.
Car: 1992 Camaro RS
Engine: 305 :c
Transmission: t5
I think im going to go the Comp Magnum route, even if I can only use a 3/8 stud. Ill keep a eye out for used rockers to see if I can find anything better, still have a few weeks before everythings gonna be ready.
1983Zsled
Aug 27, 2013 01:58 PM
BrOdBaNd
Dec 28, 2009 08:21 PM
