replaced my valve cover
Old Jan 25, 2018 | 06:54 AM
miche25's Avatar
Car: Camaro 1984
Hello, I would like to know If it can create problems replaced my short valve cover by tall valve cover.
My Chevy 305 is stock.
Old Jan 25, 2018 | 06:58 AM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
Re: replaced my valve cover
depends on ur set up.if u have a tpi ull have to remove the valve covers to get to the bottom runner bolts not really a big deal tho.other then that u should run into any problems
Old Jan 25, 2018 | 08:25 AM
miche25's Avatar
Car: Camaro 1984
This bottom runner bolts Does it can be transfered ?
Old Jan 25, 2018 | 12:18 PM
miche25's Avatar
Car: Camaro 1984
This bottom runner bolts Does it can be transfered it ?
Old Jan 25, 2018 | 05:49 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
I did that on a stock 305 TPI. The valve cover was pressed up against the air tube running to the cat causing the back corner to not seal properly which created a nice oil leak.
spiderhole
Feb 17, 2008 02:04 PM
Jester
Jan 10, 2002 10:13 PM
88 GTA Notchback
Apr 17, 2001 09:05 PM
Rob90TA
Oct 10, 2000 09:30 PM
