? for those who have replaced their valve stem seals - How long did they last?
Old Apr 17, 2001 | 04:27 PM
88 GTA Notchback's Avatar
My valve stem seals are shot and I plan on having them replaced. My mechanic told me that the heads should be redone along with the new seals. He said that worn heads would cause the valve stem seals to fail after ~5000 miles because of the worn heads.
I think he is full of ****! What's you opinion?
Jacob
Car info:
L98
138,000 miles
No major work done to it.
88 GTA Notchback
A4 / 350
Stock
** New User Name**
Kill List:
95 Mustang GT
88 Mustang GT
94? Impala (real close)
97 Dodge Neon
86 Corvette
2000 Prowler
And more Civic's then I can count. Why do they even bother?
Old Apr 17, 2001 | 04:35 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
It all depends on how worn the guides are. I replaced the seals on my old 305 and they lasted all of about 500 miles before it started blowing smoke again. Others have had better luck. A new seal can only do so much for worn out parts.
Old Apr 17, 2001 | 05:31 PM
82camaro's Avatar
Car: 82 camaro SC
With 138000 miles, I would guess the guides need replaced.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 17, 2001 | 06:07 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
Mine where in bad shape (blue smoke every morning), it cured when I switced from regular oil to Mobil 1, don´t ask me how
Later,
Nonni
Old Apr 17, 2001 | 07:55 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
My gut reaction is to say the mechanic is just trying to get you to cough up some more money. Yes, if the guides are shot that could ruin a new set of seals quickly, but that is only if they are shot. Any reason to think they are, other than high miles? If your guides are still in pretty decent shape, a new set of seals should last ... oh, a few billion miles or so. Give or take.
Old Apr 17, 2001 | 08:02 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Mine were replaced about 5 years ago, and they're going again. I think it has been about 40,000 miles (Not sure, I replaced them when the previous owner had it). I'm not gonna bother now though, since I'm gonna be retiring the LG4!
I'd be inclined to think they'd last at least 30,000 miles, or a few years anyway.
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old Apr 17, 2001 | 09:05 PM
Superblue87Formula's Avatar
My engine had 105k on it b4 the rebuild and didn't smoke at all, I am putting on new valve seals just to go to all umbrella seals and no o-rings (my o-rings were so dry and brittle they just fell off anyway..) I say try it and see what happens.
1992 Trans Am
May 10, 2023 07:19 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Leggman1
Aug 6, 2015 04:15 AM
