Can't read the timing tabs.....getting old
Old Feb 13, 2018 | 12:47 PM
Ja85z28's Avatar
Axle/Gears: 4:10
Or is this an accurate picture of my timing tab? I can see the arrows just fine.
Okay so I installed my ZZ4 intake on my 85 Z28 and went through the normal routine of setting the timimg on the stock carb/ignition system. However, I was having very difficult timing reading the numbers on the timing tab. Please varify for me that the 3 arrows on an oem timing chain cover are +4/0/-4. Thank you in advance for your time to respond. By the way, I have an appointment tomorrow at the VA Eye Clinic.
Regards,
Old Feb 13, 2018 | 01:33 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Can't read the timing tabs.....getting old
That is correct... +4/0/-4
Good luck at your appt!
Old Feb 13, 2018 | 04:24 PM
Ja85z28's Avatar
Axle/Gears: 4:10
Thanks. I broke out my good flashlight and the issue is resolved.
Old Feb 13, 2018 | 06:04 PM
Drew's Avatar
Use a dial back timing light, then all you need to see is the big V-groove.
Old Feb 13, 2018 | 06:41 PM
Ja85z28's Avatar
Axle/Gears: 4:10
My bride of 36 years bought me a new timing light for our Anniversary.....she's a keeper!!!
Lck119
Feb 18, 2015 01:10 PM
MotorMouth
Apr 6, 2012 02:06 PM
Sostar18
Aug 4, 2002 08:48 AM
jamesbern
Carburetors
Dec 21, 2001 06:35 AM
