89 RS 2.8 110,000 miles
Old Feb 18, 2018 | 06:15 PM
dimelog1's Avatar
Bought this car a week ago. It starts fine, idles fine. Getting it up to speed it seems to lack power. I tested the tps it is good. It was having a 22 and 32 code. Found some vacuum lines not connected and plugged. Checked egr and it holds vacuum and pressure and I hear the diaphragm inside clicking up and down. New plugs, wires, coil, ecu on distributor, cap, rotor. Cleaned maf sensor and it looks ok. Noticed on bottom of throttle lever a cable that is not hooked up. Looks like it goes to a round canister by front of car. Timing possibly off? Not sure what to check from here. Any help would be appreciated.
z281982
Aug 11, 2010 12:43 PM
iroc_nv14
May 5, 2006 11:49 PM
fitbmxseries1
Oct 14, 2005 01:59 PM
