distributor cap
Old Apr 2, 2018 | 03:51 PM
miche25's Avatar
Car: Camaro 1984
distributor cap
It may seem ridiculous, it's because I break nothing!
The little hat that holds the bottom of the spark plugs
, is there a way to remove it
without breaking? Is there a clip?
Old Apr 2, 2018 | 04:40 PM
Drew's Avatar
Re: distributor cap
You mean the ring on the distributor that the plug wires are clipped into? It has a lock or latch on each side of the coil. Should even say "press to unlatch" or something similar.
Old Apr 2, 2018 | 05:42 PM
miche25's Avatar
Car: Camaro 1984
Re: distributor cap
Thank you for your answer, I will check tomorrow !
Michel
mike_c
Feb 3, 2014 05:35 PM
gcj280
Dec 5, 2013 07:25 AM
Looksthakill
Alternative Port EFI Intakes
Feb 13, 2011 08:32 PM
jayk2k3
Aug 20, 2008 07:55 PM
