Oil pressure sending unit issue?
Old May 10, 2018 | 07:25 PM
sgeorges714's Avatar
Car: 1987 Z28 Vert Special Edition
Engine: 305 TPI LB9
So today I changed my oil pressure sending unit because my gauge was really jumpy and inconsistent. However, now it stays in the red (roughly 10lbs I'd say) when I'm driving. When I let up on the gas it goes to zero. My sending unit was next to my distributor cap and I purchased a unit that is 0-60 which is what my gauge reads so I know it was the correct one. I'd like to know if anyone here has experienced anything similar and what was your remedy. Any help appreciated thanks.
Old May 11, 2018 | 08:56 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Oil pressure sending unit issue?
My oil pressure gauge reads about 20 PSI higher than my aftermarket mechanical gauge. Duralast sensor. I think they have a lifetime warranty maybe I should try swapping another
Old May 11, 2018 | 06:28 PM
NoEmissions84TA's Avatar
Were you able to check for any crap in that passage where the sensor screws in?
When I changed my sending unit in my truck, the new one read way lower than previous.
Bring it back and try another sending unit.
Donald Croes
Jul 3, 2016 12:19 PM
calicompliant
Mar 8, 2012 07:43 PM
mikesz1984
Alternative Port EFI Intakes
Sep 21, 2009 01:34 PM
BOWTIROC
Carburetors
Nov 3, 2000 03:00 PM
