HEI and vacuum advance
Old Jun 19, 2018 | 09:27 PM
Siber6's Avatar
Hi, I have an old Ford 352 that I put an HEI distributor on with a vacuum advance adjustment inside the vacuum. Im not sure if I should put the hose to the left or right side of my Edelbrock 4 barrel carb? One side has vacuum at idle and the left side does not?
Old Jun 19, 2018 | 11:34 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
Re: HEI and vacuum advance
Either source can work. The vacuum source at idle (manifold vacuum) is what I would recommend. Using this source you will need to readjust your base idle RPM as the idle would likely jump a little when you first hook it up. The other source, sometime called ported or timed vacuum as I understand was introduced to assist early emissions controls.
There are those that swear one or the other is 'best' and can come down engine/cam combo or personal preference.
My dad has a '59 Fairlane Galaxy 500 with a 352 and an Eddy 4 barrel. We used the stock distributor but set up the vacuum advance on manifold vacuum and it works just fine.
Out of curiosity, do you have this Ford 352 with a GM distributor in a 3rd generation Camaro?
Old Jun 20, 2018 | 08:50 AM
Siber6's Avatar
The distributor is a GM with a Ford lower end, and it is in a 76 F150. Im going to tinker with it today and try both sides driving; the left port retards the timing slightly at idle because there isnt any vacuum, I believe it opens up as the RPM's increase and the drivers is constant?
HEI and vacuum advance-screen-shot-2018-06HEI and vacuum advance-fullsizeoutput_280.jpeg
kentuckyKITT
Nov 8, 2018 06:09 PM
weaz4200
Jun 1, 2018 11:46 PM
NTXCAMARO
Carburetors
Apr 9, 2018 04:37 PM
greasegrenade
Mar 13, 2017 11:07 PM
Wayquick4u
Mar 13, 2001 06:50 AM
