Engine question
Old Jul 17, 2018 | 08:22 AM
Skipin45's Avatar
Car: 1990 camaro
Engine question
What's the difference between these two engine setups? The pros and cons?
Old Jul 17, 2018 | 03:09 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Engine question
170hp 255 ft lb tq vs 205-230hp 300 ft lb tq. That is if they are both stock 305s. Who knows bout the engine on bottom it looks to have been out at one point.
Old Jul 17, 2018 | 03:14 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Engine question
The top one is , depending on year , either a computer controlled carb or a "TBI" , Throttle Body Injection . The bottom one is a "TPI" Tuned Port Injection . Mostly it's a personal preference type of thing , with most folks considering the TPI as being more modifyable for a bit more power over it's stock configuration . Some folks hate the TPI and ditch it for a straight (non computer controlled) carb , and some folks will go as far as to buy an aftermarket TPI controlled by such an aftermarket computer as the "Megasquirt" system .
Personal preference is what it comes down to , since either system CAN be modified to the owner's vision of what they want their car to be .
So , which one do YOU like better ?
Old Jul 17, 2018 | 03:44 PM
Skipin45's Avatar
Car: 1990 camaro
Re: Engine question
my car is the top one and it's bone stock it's a 305 TBI I'm just looking ways to make it faster. Can you change the top one to the bottom one? What's the best way to get the most performance out of the motor?
Old Jul 17, 2018 | 03:46 PM
Skipin45's Avatar
Car: 1990 camaro
Re: Engine question
my car is the top one. I'm just looking for ways to make it faster.
Old Jul 17, 2018 | 06:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Engine question
Trouble with TBI systems and making power is that you can only flow so much fuel through 2 injectors and they have limits. With a TPI system, you have 8 injectors so each cylinder can get more fuel from an injector swap to make more power.
A 454SS pickup truck ran TBI which is larger than the SBC TBI system. Even with 454 CID, the injectors limited it to around a maximum 330HP
Old Jul 18, 2018 | 07:05 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Engine question
Then first things first. Headers and matching y-pipe, 3in exhaust system, a posi with 3.42 gears,2400 stall torque converter, shift kit. Save your $ for a 350 engine down the road.
Old Jul 19, 2018 | 02:35 PM
Skipin45's Avatar
Car: 1990 camaro
Re: Engine question
OK, thanks for the info
Old Jul 19, 2018 | 10:22 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
Re: Engine question
The TPI is the best looking factory small block ever produced imo.
Old Jul 19, 2018 | 11:14 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Engine question
I agree Jbuchanan
90-Vert
Oct 3, 2010 03:56 PM
'86 350
Carburetors
38
Oct 16, 2007 09:55 PM
JamFitz
Apr 12, 2007 11:56 AM
easySPEEDcamaro
Feb 26, 2003 07:31 PM
bzznczzn
Jan 8, 2002 02:01 AM
