91' 5.0 GTA acting up
Old Jul 30, 2018 | 04:32 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
The car sometimes loses power.. usually going up hill and then the ses light comes on.. anyone have any ideas what it could be?
Old Jul 30, 2018 | 06:52 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: 91' 5.0 GTA acting up
Start with the simple stuff first. What code is the SES light showing? If it is running lean, then change the fuel filter. Might be running super lean because of a clogged filter. Had something similar happen to me many years ago.
Old Aug 8, 2018 | 08:04 PM
Engine: V8 305
im not sure what code is running.. i just ordered a obd1 reader to see exactly what the code is. I replaced the fuel filter in 2016 after i purchased it, i just put a cheap one in there tho. i cud probably replace it. Could it be the maf sensor?
Old Aug 8, 2018 | 09:14 PM
Drew's Avatar
Oh you don't need a scanner. A paper clip or scrap of wire bent into a U and inserted into A and B of the ALDL, turn the key to run, count the flashes of the check engine light. Codes are two digits. It'll start by flashing code 12 two or three times to let you know it's in diagnostic mode, so one flash, pause, two flashes, pause, one flash, pause two flashes.... After code 12 it'll flash any other stored codes. Each code will flash 2 or 3 times, then it'll move on to the next code, when all the codes are finished, it'll flash 12 again 2 or 3 times before repeating the process. When you're done, turn the ignition off, remove the clip, and fix the problem. When the problem is fixed, disconnect the battery for 30 seconds to a minute, reconnect and test drive the car. That will reset the codes, so you can drive the car a bit and check the codes again to see if they come back again.
bryan623
Oct 16, 2014 01:03 PM
GTA88
May 28, 2009 11:37 AM
theCure
Jun 27, 2007 08:49 PM
super83Z
Carburetors
Jul 22, 2001 10:59 AM
Bjorn
Oct 13, 2000 08:20 AM
