Engine surging when idle
Old Aug 2, 2018 | 03:37 PM
Berlinettaowner's Avatar
Car: 1985 Camaro Berlinetta
Engine: 2.8L V6
As the title says.. the engine is surging when in idle. To give some vehicle context - 1985 Berlinetta with a 2.8L v6.
Every once in a while it'll surge up to around 1700 or so then when it goes back down it stalls out. If I give it steady gas it stops surging. The surging is also intermittent. If it hasn't run in a while it doesn't happen either. But if the engine is still hot it tends to do it more often.
From what I've read, it could be a vacuum leak. I've heard the soapy water trick works reasonably well for this problem in finding where it is. Any other ideas that may work better?
Also, can I get a schematic or something on how the vacuum lines are run? I'm new to the car game so keep that in mind.. Thanks!
Old Aug 2, 2018 | 05:36 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Engine surging when idle
I used starter fluid to find my leaks.
Old Aug 7, 2018 | 03:53 PM
Engine: 2.8L V6
That makes sense. Spray on the vacuum lines and if there's an increase in power there's a leak.
I'll have to try that out. I'm sure I need to be mindful where I spray?
NArtissimus
May 7, 2013 09:20 AM
SRRF
Sep 24, 2011 04:56 PM
83z28Browner01
Sep 23, 2010 01:03 PM
whoaru99
May 20, 2005 09:37 AM
Xenodrgn
May 13, 2001 12:54 PM
