EGR Solenoid Power at Idle/Surging & Rough Idle
Old Aug 28, 2009 | 03:52 PM
SRRF's Avatar
Hello everyone,
My car is a 90' 305 TPI IROC...
I ran into problems with my EGR solenoid (kept stalling on me while driving) so I ordered a new one and disconnected power to the solenoid.
I drove my car (with no issues) untl the new solenoid arrived today ...
The new solenoid takes a new connector (which I had one laying around the garage) that I put on... however, when all is hooked up the car surges and the RPM bounces at idle...
Using a test light I checked that there is a complete circuit with the connector at idle... in other words, at idle the test light is on when connected to the electrical connector
I was curious if there was suppose to be a constant current to the connector or if it was suppose to send pulses of current to the solenoid... Either way the circuit is being complete at idle...
Keep in mind... the old connector and solenoid worked, but stalled once and a while... the new connector/solenoid make the car un-drive able... which leads me to believe it's the electrical connector...
Curious everyone’s thoughts on this,
Old Aug 29, 2009 | 12:40 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: EGR Solenoid Power at Idle/Surging & Rough Idle
Originally Posted by SRRF
Hello everyone,
I drove my car untl the new solenoid arrived today (with no issues)...
maybe the leads are reversed. i had a the problem when i disconnected the egr solenoid. my rpm wouldnt come down. so a burn out result in a scary situation. good luck. vacuum test everything
Old Sep 8, 2009 | 07:30 PM
SRRF's Avatar
Sorry, I'm a bit daft...
What do you mean by the leads?...
As in the two wires I soldered together with the new connector or do you mean the two vacuum lines?
Thanks again
Old Sep 8, 2009 | 07:44 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Where did you get the solenoid? It has been discontinued for awhile now. What brand and part # is it?
Old Sep 9, 2009 | 12:32 PM
SRRF's Avatar
ah, I had a hard time finding a solenoid... however I ended up getting one from RockAuto...
The part is an Airtex part number: 2F1101
A part number search on Rockuto.com should bring it up...
Thanks for the reply
Old Sep 16, 2009 | 09:18 PM
rokbun2's Avatar
Do you still have one of the EGR Solenoids? Will it fit a 5.7 1991. Either way, let me know so I can gain some knowledge. Sorry bout your issue.
Old Sep 17, 2009 | 10:05 AM
SRRF's Avatar
I do have the solenoid, for whatever reason it seems to surge on my car...
My engine is a 305 TPI... I assume the solenoid is for a 5.7....
Although, I didn't think it should matter which engine size it goes on, as a solenoid is generally a vacumm switch... correct me if I'm wrong?
I'm just not sure why the new solenoid would make the car surge and run horrible... while the stock one did not?
Old Oct 18, 2009 | 04:21 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
the solenoid you bought is for a TBI engine, thats why its different, but if you got the connector to work then it should be fine. the plug should have NO power in park or neutral at all, if you jumper the ALDL pins A&b like you do when you check for codes then the plug will have power. otherwise no power unless in a gear and under certain conditions.
Old Sep 24, 2011 | 03:57 PM
F-body-fan's Avatar
How did you make out with this delima?
I am trouble shooting my EGR & Solenoid on a 87 TPI & the one thing that throws me off is that the TB port that the solenoid plugs into appears to be a ported vacuum source. So, weather the solenoid is on, off, leaking or defective it would appear it couldn't effect the idle? So would this make it impossible for the solenoid or EGR valve to function at idle?
Old Sep 24, 2011 | 04:56 PM
F-body-fan's Avatar
Just took it apart. The solenoid is working fine. Sealed & open when not energized,
Closed, but vented when energized.
jklein337
Sep 19, 2018 06:23 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
