V8 350 Engine Running Rough
Old Aug 14, 2018 | 12:48 PM
1995Z28Camaro's Avatar
Want a title? Post!
1995 Z28 Camaro, standard transmission.
Mechanic drove the car and thought one of the cylinders is not working. Not sure how to diagnose the issue.
Old Aug 14, 2018 | 02:09 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: V8 350 Engine Running Rough
I would check a 4th gen board but if you think one cylinder is not working then you can pull one plug wire at a time and see what cylinder does not make the engine run worse.
Old Aug 14, 2018 | 03:27 PM
T4Turtle's Avatar
Car: 1987 Fiero GT
Transmission: 5 speed Getrag
How old is the opti spark?
Mark_ZZ3
Jan 30, 2025 01:34 PM
gcj280
Apr 25, 2017 04:43 PM
Rafi1123
Sep 15, 2016 06:51 PM
aussiesteve
Sep 12, 2016 02:21 AM
84Elky
19
Jan 10, 2015 07:39 AM
