Gasoline and long term storage ???
As some may know, I exported my 1992 Trans Am GTA 3 years ago. The country it's in thankfully has old school ethanol-free gasoline. I had filled the tank, added Sta-Bil, and done a fresh oil change with Redline. Once a year I've been running it up to full temp for about 30 mins and various lower RPMs. Now that it's 3 year old gas, I'm going to pump the tank dry tomorrow and fill it with fresh gas. I wanted to get some input on strategies to ensure the gas stays as stable as possible for as long as possible.
First, I know that octane level decreases with age, so I'll be filling it up with 95 RON. Second, I'll be adding more Sta-Bil as that's about all I can buy in this country.
Third, I'consdiering adding SeaFoam. My reasoning for this is that running my car on the aging gas inbetween tanks is probably gumming up my injectors a bit which were nice new Bosch III a few years ago. Also I think it may help my fuel pump too, which is also new as of several years ago.
What does everyone here think? Will the Seafoam interfere with how Sta-Bil works? Should I add a higher than specified amount of Sta-Bil and will that help? Should I be adding an octane booster every year? Should I be adding more Sta-Bil every year? Shoud I add more SeaFoam every year? I'm just trying brain storm some strategies.
Thoughts, comments?
Thanks!! Alex
Thoughts, comments?
Thanks!! Alex
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Gasoline and long term storage ???
Check out Carb Defender by Driven products...
Thanks but I know for sure the local auto parts doesn't stock that :/
So it looks like SeaFoam bills themselves as being a fuel stabilizer like Sta-Bil. So maybe I should instead do Sta-Bil and a large bottle of Techron?
Dammit, also just found out I should have been adding Sta-Bil each year, not just once. Grrrr, lesson learned on that one.
Attached is one of the buckets I pumped out of my tank this morning. That's a little over 3 years old with Sta-Bil added. The car fired right up and run just fine, and it left no residue on the inside of the gas tank surprisingly.
So I've learned a few things from this experience. If I let it go to a 4th year, it looks like that varnish color would start taking on physical properties and start leaving a gummy film so I got it out of there just in time. Due to the system being so sealed and my car being kept in a shipping container in a hot climate, there was ZERO moisture in the tank/fuel from what I could tell (I removed the fuel sending unit to pump out the fuel so I got a good look and removed every last tiny drop).
That said, I think what will work for me is only putting a couple gallons of fuel in it with Sta-Bil and Techron added and run it to get all the old fuel out of the lines and fuel rails. Each year I'll add a fresh gallon and the appropriate amount of Sta-Bil and Techron to it and run the car for the 30 mins for a few days in a row (like 2 or 3 days). I also put it into reverse and drive for a bit as well and creep the car forward and back each year to ensure the brakes don't freeze and the tires don't flat spot totally.
My low-speed electric fan stopped working so the high-speed one kicks in at 220, nice and hot, and keeps it there even cycling on and off with no problem.
Engine: 4++,350 & 305 CIs
I think keep on doing what you are doing and it'll be fine. Hope things are well your way!
Irma really did a number and I lost everything in the house but everything in the 40ft container was untouched. Unfortunately, I had several now impossible to find and priceless NOS parts in the closet of my master bedroom thinking that was the safest place. The opposite happened and everything in that room was a complete loss. Really sucks. Even lost most documentation for the car, except for the original window sticker that was in a frame in another room. Things like NOS taillights, a fully refurbished factory CD player that was the best of 3 I had redone by that company with the very last of the parts they had, NOS center console and NOS lid, and a box filled with small parts like NOS center caps, PW switches, mirror switch, stuff like that.
Worst of all, the homemakers only covered damage to the house, nothing personal inside. That's just how policies are written down here unless you pay WAY extra and document literally everything.
Oh man that's horrible... but glad everyone is ok.
Transmission: World Class T-5
Axle/Gears: BW 3.45
Sorry to hear about your losses.
I think it's important to keep the tank near full in storage. That will keep condensation in your tank at bay.
Car: 88GTA
Engine: 5.7TPI
Good to hear from you! You moved down there to be with you Mom, correct? Hope all is well with the family. I do have a question though. It looks to me everything you are doing to keep the car up is working. But how long do you plan on doing that? What is the end goal of keeping your car in a shipping container? Just curious, that's all.
Take care!
Take care!
I'll give that more consdieration. Even though I had no moisture contamination, I suppose I may have to worry about possible surface rust inside the tank above the fuel level.
Take care!
Take care!
To answer your question, I have no idea. I just know that after more than 18 years of ownership I never want to part with it. I'm still a broken man from having to sell my 1956 Corvette haha! I'm more determined than ever to never sell the GTA. Once I finish building on a garage to the house end of 2019, it will move from the container into the garage with a dehumidifier (maybe into a CarCoon). Who knows what the future holds, I just know I'll still have my GTA.
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I believe on the Stabil Bottle it has amounts to last 2 years, not sure how much you added...
Some people don't like that it's red and "stains" things...
I've used it personally on cars, lawn equipment, and NEVER had a problem...
Gas has never SAT over 2 years in any of my items, but still, no problems starting / running things...
Rafael
Rafael
I would have to wonder if it wouldn't be better to drain the tank, and let what remains evaporate, when storing for such a long term. Pull the plugs, fog the cylinders, put the plugs back in, stuff rags in the tail pipes and intake... Make a checklist of all the things undone for storage and hang it on the rear view, then when you get back to it, remove all the rags, add gas, cross fingers and go.
I have some fresh gas with stabilizer and Techron I'll be putting in early tomorrow morning and running it for a while.
The less exposure to oxygen (causing oxidation and break down) and air (evaporation) the better, so you are better off with a full tank and full fuel lines. Humidity/condensation is more of an issue with ethanol added (you said no ethanol in your gas), since alcohols are hygroscopic, attract and absorb water which in the end causes the sludge/breakdown to get worse and also causes corrosion (our fuel lines are not stainless, unless you have flex fuel injectors even the pintles on most injectors will rust...
I've had MUCH better luck with the Marine Stabil (the blue stuff) than the normal stuff. I've stored stuff with even chit ethanol gas in it for 4,5,6 maybe more years with this stuff in it and it started right up when I came back to it, but I also usually put it in at about 2x the recommended dosage and let it run around for a while before shutting things down. I doubt the injector cleaner is doing much for you, if the stuff runs it's probably OK. OTOH, if it makes you feel better, the Techron stuff is good stuff... I don't see it hurting.
I'm with Drew on fogging the cylinders (I'd probably just use ATF but there are spray fogging products just for this). Some corrosion in the bores and the ring wear/damage at startup is potentially a much bigger $$$ problem than the fuel system plugged up. Same with blocking off the intake and exhaust. I had a car that I thought was carefully stored that some squirrels figured out how to get acorns into the intake and that was a mess to get going again, I had to take the intake manifold off and clean it out. I would also duct tape off the cowl vents (heater boxes are famous for being mouse nesting places) and if you've punched any holes in grommets (I had a car that I put a small hole in grommet in the spare tire well to run an N2O line out and even with the N2O line in it somehow a mouse figured out how to use it to get in and out and used my bottle blanket as nesting material and ate through my bottle heater).
Once you get it all stored I wouldn't mess with it till you get ready to run it again. Then change the oil, clean everything up and run it (If you have a truck or something you can drain the gas off into that and burn it, but honestly with the blue stabil in it I'd run gas multiple years old). Messing with it in between times is likely not gaining you anything unless you notice something you missed, of course you could forget it this time...
Ozz1967
Aug 25, 2008 07:48 PM
V8Rumble
Jun 30, 2006 05:37 PM
Paul Riccioli Jr
Dec 17, 2000 11:03 PM
